Wiring diagram
Username: Iufan4lifeul
Post Number: 635
Ok, can anyone draw out or describe how to hook up a 2 channel amp to 1 dual voice coil subwoofer? Can I literally just run the positive wire from each channel together and then put that into the terminal and the same with the negative or what? What loads would that give me?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 815
is the sub 2ohm or 1ohm
Username: Rovin
Trinidad & T...
Post Number: 1904
post the amp & sub model no.
Post Number: 636
Kicker 450.2 for the amp and Kicker CVR15 (don't remember if it is dual 2 ohm or 4 ohm).
Post Number: 819
oops i meant 4 ohm
if its like the JL subs the jumpers for the ohms are on the sub itself so you should be able to just use what is set for the bridge channels into the corresponding terminals. maybe?
