Vented Box 2 10" Xplods
Username: Stefangoalie
Lakeville, Minnesota
I have two 10" sony explod subs in a down firing enclosure under the back seat of my 95 chevy ext cab. I want remove the back seat and build a vented enclosure to get the most SPL out of my subs without sacrificing all of the sq I have now, which isnt much...
I am running a Diamond 300x2 amp. The subs are single voice coil 4 ohm. Any help would be great, I am new to this scene, but plan on ungrading the subs soon, so a little more box than i currently need would be fine. I have plenty of room, so thats not an issue. Thanks Alot
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 105
first of all....every sub is different, and requires its own custom box. Second, if you plan on upgradeing your subs soon but just want to build the box now, my suggestion would be figure out which new subs you want, build the box to those specs, and if you just want some bass until you get them, throw the sonys in there. just my 2 cents
