2 KICKER L7's fit in a 89 ford Escort?
Username: Mixmastaspig
Okanagan, B.C Canada
Post Number: 124
Just wondering as I still want to be able to have my back seats...just loose my trunk space is what im lookin for!
thanks!
Username: Robert_d
MIA, FL USA
Post Number: 179
what size L7's cause they go from 8" to 15" you should be able to fit 10" pretty easy my friend has a 97 escort wit 2 mtx 10" he can fit 12" so im pretty sure u could also
Post Number: 125
Yeah Id be looking at 12", I have 2 Type R's 12" but the box is bassworx, so a box to specs for the L7's would be ALOT bigger, I just want to make sure that it would fit in the car!
