slaya Unregistered guest | Hey, i'm on somewhat of a budget and I want some decent bass. I don't need top of the line equipment but I would like some bass. I'm looking for probably 1 sub, in the price range of $70 (could be bought from anywhere, ebay, cheap online store, ect) What would be the best sub I could get for this, and if anyone could recommend a cheap amp aswell this is one I am considering http://www.cardomain.com/item/PIOTSW306C Thanks |
Silver Member Username: TdbdadrummerPost Number: 286 Registered: Aug-05 | Hey, Isaac or Muddy, or Glass or someone, doesn't RE sell a sub for <$100 that this kid could buy? |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1538 Registered: Aug-05 | yeah, the Resonant Engineering RE is $77 |
Silver Member Username: TdbdadrummerPost Number: 290 Registered: Aug-05 | Well, wouldn't that sub be better than the Pioneer he's looking at!? |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1546 Registered: Aug-05 | YES!! |
slaya Unregistered guest | thanks guys, appreciate it very much.. one last thing, where did you find it for 77$? actually, where did you find them at all? thanks again |
Gold Member Username: Basshead86Ocala, FL USA Post Number: 1551 Registered: Aug-05 | www.reaudio.com they are $69 before shipping. |
slaya Unregistered guest | so evan though these are 175watts and the Pioneer is 600 watts, these will bump harder/louder? |
Silver Member Username: Robert_dMIA, FL USA Post Number: 118 Registered: Sep-05 | depends on the enclosure although the re is 175 rms 350 max watts and the pioneer is 300/600 the re should do better overall if u want u could go with a 12" type R its 100 after shippin on ebay its 500/1500 but keep in note that max doenst mean much its better to go with rms rattings if your going with a type r be sure its a 2005 model which are greyish color and make sure its voice coil match your amp wiring setup |
Silver Member Username: Monkey_manPost Number: 314 Registered: May-05 | What about a cewin vega v-max. They are anywhere from 70-85 dollars on ebay and they pound pretty d@rn good. |
