Kicker c12a
Username: 69vwvan
Winamac, Indiana USA
Post Number: 13
i just got two new kicker comp subs. Not the new ones but the old ones that have a red/white square thingy in the middle of it. Does anybody know how much wattage these things would be?
Username: Sploosh56
Ohio
Post Number: 914
should be like either 125 -150 rms. I liked them subs when they were out. Put them in either a big sealed box or a ported box tuned to 30 hz.
Username: 69vwvan
Post Number: 14
yeah.. both of them are in a big sealed box. for an amp, i have a bazooka 300.1 (350 rms @ 2 ohm) or i have a kenwood kac-744, another older style. Im not sure how much wattage the kenwood is though, which amp do you think i should put the subs on?
Username: Sploosh56
Ohio
Post Number: 915
if those subs are single 4 ohm then jsut use the bazooka amp and wire it for 2 ohms
