Want subs that hit hard
Casey08
I want (2) 10" or 12" subs for the trunk of my 69 mustang coupe, dont want to spend more than 100 per sub...Also want good SQL.
Username: Jonesp
Post Number: 36
kicker comps not VR's
98 a pop
astrosafari7733
less than 100? ur not asking for very good quality are you.
Username: Chrisklein
Post Number: 254
get 2 12 RE series subs from Resonant Engineering. They are some of the best "budget subs" you can get. They have got to be the punchiest subs i have ever heard.
Username: Taylor17
Kopperl, Texas
Post Number: 2965
Yup, I'd go with the RE RE's...
Kicker Comps,
Rockford HX2's, if you can find them for that cheap.
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 268
also dont forget about the Alpine Type Rs off ebay
