Amp for this
12345
whats a good amp for this
http://www.ikesound.com/product-product_id/3565
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 256
whats your price range?
well ill give you some cheap and good amps
JBL 600.2
Kicker 600.1
MTX 801D or sumthing like that
12345
ya i dont want to go to expensive and would 600 watts be enough
Username: Quickshot
Post Number: 257
o rms on that is 750 i didnt even notice that...yea 600 is alright but you should look at the Kicker KX 800.1 or the MTX 801D or MTX 942 off ebay if you want a lil more power at a good price
Username: Camaro155mph
Post Number: 159
hey quickshot, i've heard that Kicker amps draw a lot of power from the alternator, is that true, becuz i am thinking about the kicker 1200.1, but if it draws a sh!tload of power, than i will look at something else....
Username: Basshead86
Ocala, FL USA
Post Number: 1331
it will draw only as much power as another amp Class D amp that does 1200wRMS.
