Bronze Member Username: Biggyg9712Post Number: 16 Registered: Sep-05 | i have 400 dollars that i want to spend on a sub and amp, im most likely going to buy everything on ebay...any suggestions on what i should get? |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 55 Registered: Jan-05 | So do you just want a sub and an amp?Do you have more money set aside for a box an wiring kit?What type of music do you listen to?What kind of space do you have?Do you want sq or spl? |
Bronze Member Username: Biggyg9712Post Number: 17 Registered: Sep-05 | i have the wiring and the head unit..im spending 400 on the sub and amp. i listen to rap..my car is a 2003 toyota camry..and what is sq and spl? |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 56 Registered: Jan-05 | sq is sound quality and spl is sound pressure level. |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 57 Registered: Jan-05 | You can go with a MTX T7515-44 and power it either by a TA3401 or TA2301.If you power it by the 3401 it will come out to like $405 shipped but if you go with the 2301 then it will be like $375. You could also go with a Kicker 05S12L5 powered by a 04KX600.1 for $384.These are all on ebay. |
Silver Member Username: Sploosh56Ohio Post Number: 882 Registered: May-04 | try a pair of kicker comp 12's in the 8 ohm version and a kicker kx250.2 amp |
Bronze Member Username: Biggyg9712Post Number: 19 Registered: Sep-05 | i got a alpine type r and a alpine mrd-m605 is there any thing i can get that is better than this for 400 dollars? ispent 400 on the alpine stuff |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 58 Registered: Jan-05 | I looked for the Kicker 05C128 which Wahl was talking about on ebay and I couldn't find any 8 ohm ones.But one place that does sell them and the amp is Circuit City so the 2-12s and the amp would be $380 and thats shipped. |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 59 Registered: Jan-05 | What size type r? |
Bronze Member Username: Biggyg9712Post Number: 20 Registered: Sep-05 | a 12 inch running at 500 rms |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 60 Registered: Jan-05 | Thats not bad are they new? |
Gold Member Username: InvainMichigan United States Post Number: 3579 Registered: Aug-04 | With 400 bucks, I'd probably get an RE Se 12" or a 12" ID IDQ, and an Xtant A6001 - Xtants are really cheap on ebay right now for some reason... |
Silver Member Username: TdbdadrummerPost Number: 117 Registered: Aug-05 | Hrmmm, I'd go with what Joe said! |
Questions. Unregistered guest | some good 6.5 inch speakers http://cgi.ebay.com/INFINITY-6002I-6-5-2-WAY-180W-CAR-SPEAKERS_W0QQitemZ58079589 63QQcategoryZ58025QQrdZ1QQcmdZViewItem ?? |
Silver Member Username: Alias747MN Post Number: 647 Registered: Apr-05 | YEAH JOE, you noticed that too?? I have been looking the last couple of weeks and noticed that. It's sad really, because people just don't realize how excellent of a company Xtant is. And then the people/businesses selling them think they are junk because no one wants to pay for them. There are way too many crappy mainstream companies that are over-hyped. |
Bronze Member Username: HomegrowncamWatauga, TX United States Post Number: 63 Registered: Jan-05 | Wasn't xtant made by mtx? |
Gold Member Username: InvainMichigan United States Post Number: 3598 Registered: Aug-04 | They are owned the the same company, yes, but that doesn't effect Xtant's quality. Isaac W: The prices are rediculous right now. I was gonna get a PPI Art to run my components, but when I checked Ebay for other stuff, just to be curious, I couldn't believe it, so I ened up getting an Xtant 202m. |
