Cast your votes: BEST SPL SUB ON THE MARKET
Username: Phuktupbasshead
Scottsdale, Arizona United State...
Post Number: 211
For this one, price should not be an issue. Please vote to indicate YOUR CHOICE for BEST SPL SUB ON THE MARKET. Your expertise, knowledge, first hand experience, and opinions are greatly valued and appreciated. First hand experience is, without a doubt, the most accurate vote - however all input is welcome. An explanation for your vote is not required, but encouraged.
We thank you very much for participating.
Voting results will be revealed within 1 week.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 778
vote: DD 9917
just an opinion. no experience with it. i know DD audio does SPL right though. its an insane SPL woofer though
Username: Suleman36
Maryland U.S.A.
Post Number: 2095
DD 9500 / DD 9900 Series Subwoofers
Resonant Engineering MT series
Username: Subfanatic
Ky
Post Number: 4791
RE MT/MTX JACKHAMMER if it was released to the market.
Username: Jundi
Post Number: 12
From what i have heard RE MT or 18" Solo X
Username: Acevolkov
Springfield, Missouri United Stated
Post Number: 114
18" MT
Username: Mtxaudiouser
Post Number: 12
22" mtx jackhammer
Username: Bigatna
Colorado United States
RE MT series gets my vote
Username: Basshead86
Ocala, FL USA
Post Number: 747
Treo SSX or CSX:-)
SSX
CSX
Username: Big_oso
Post Number: 436
shocker pwns
Username: Mike_anthes
Canton, SD USA
Post Number: 303
atomic apocolypse X 18's...havent heard them but some numbers look pretty decent...
Post Number: 231
thanks, guys!!
anyone else?
Post Number: 245
ALL I ASK IS:
If you're reading this, please don't leave without voting. Thanks.
Username: Deezel
Post Number: 38
18 inch Eclipse Titanium Pro. It has an Xmax of 87.5 mm (3.5 inches). It can handle 3000 watts RMS.
It also has, like the regular titaniums, the QCA (Quick Change Assembly), which lets you unbolt, and then unscrew the cone, surrond, and spider from the motor, so you can keep the motor (the most expensive part of the wooder usually), and just buy the top half for much cheaper then a whole new woofer.
Plus it still retains decent SQ considering.
Username: Taylor17
Kopperl, Texas
Post Number: 2817
Hmmm, so minny to mintion.
Eclipse 18 TI pro
18 RE MT
Adire Parthenan
TRF2212
DD 9917
Glad I could help.:-)
Username: Scubasteve
Annapolis, MD
Post Number: 492
Clearly, its the Parthenon. However, it'll probably turn your car into shrapnel and your neighbors houses will be in the blast radius. :-)
Username: Taylor17
Kopperl, Texas
Post Number: 2825
Lol and the price will drive the rest away.
Post Number: 254
bunp
Username: Kravenblood
Cerwin vega stroker pro 15 sql sub with amazing spl
Username: Bigpimpn0789
Springfield, Ohio USA
18" solo x by kicker 5000 watt RMS and 10000 watt peak try beatin those numbers
Username: Carguy
Post Number: 4196
RE MT met that challenge.
