New member Username: Brady427Post Number: 5 Registered: Sep-05 | I have 2 Kicker CVR12 in my truck right now. I am wondering if i will have better SPL from a 15 then these 2. I am leaning towards getting a JL13W7. But i just want to know if it will be louder. |
Bronze Member Username: DeezelPost Number: 31 Registered: Jul-05 | While I don't know about being louder, I am pretty sure with the right amp you will have an equal amount of SPL, but the JL will sound much better. However, JL is really overpriced. Why not try and 15 inch RE SX or a 15 Eclipse Titanium. Much cheaper, and just as good as the 13W7, if not better in some aspects. |
New member Username: Brady427Post Number: 6 Registered: Sep-05 | I havent heard alot about the Eclipse. Give me some info on it.....also, if i were to stay with the 2-12" config. i am going to upgrade. Reccomend 2-12" under $400. THANX |
Gold Member Username: Taylor17Kopperl, Texas Post Number: 2813 Registered: Jan-05 | A 13W7 will prob be louder... depending on what amp you have now, or will use with the w7. JL is a little high, but great stuff. RE is at www.reaudio.com. and the Eclipse TI's, www.woofersetc.com has pretty reasonable prices on them. The Eclipse's are 750 watts rms, but can handle 1000 watts, and is an sql sub. |
Silver Member Username: Dz43893Chicago, Illinois United states Post Number: 270 Registered: Jun-05 | i found that at Electronicgiant.com the 12's r for 319 and the 15's r for 355 |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 160 Registered: Jul-04 | Hey Brady Fedro I will buy you Kicker COMPVR's off ya! How much you want for them? |
Bronze Member Username: Brady427Post Number: 11 Registered: Sep-05 | make me an offer.... |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 162 Registered: Jul-04 | Well I can get a brand new pair on ebay for 160! How old are they? Are they the new model. In good condition! Well tell me what you want? |
