Silver Member Username: FordpwrLos angeles, CA Usa Post Number: 318 Registered: Dec-04 | I think I just blew one of my 15" x.x.x., not sure though. Is it possible to blow one with 1200 w rms ? I had bought a new CD and went to put it in. played fine for a while then a low muzzled 'pup'. And now no sound. I pulled it out of the enclosure, checked the wiring,OK. Then I switched to my 18" and played fine. So its a Sub problem. Still under warranty though. I'll call RE tomorrow. My question is, Is there another comparable sub I can get? I called RE and they said that the x.x.x. wont be in production 'til another 2 months( I haven't mentioned my sub problem yet) and I need another 15" sub comparable to x.x.x. ,in both SQ and SPL, by the end of the month. |
Silver Member Username: Rob315Cuse, NY U.S. Post Number: 583 Registered: Jan-05 | it is definitely possible if you were sending a clipped signal. |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 734 Registered: May-05 | Available: ID max Sound Splinter RL-P |
Silver Member Username: Big_osoPost Number: 426 Registered: Jun-05 | sell me your xxx so i can repair it i know exactly whats wrong with it but im not sure exatly how to explain it |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9241 Registered: Dec-03 | call RE and tell them its blown they can repair yours. you had the gain set too high on your amp or you need more current for the amplifier. a clipped amp is what blew the sub. you'll blow any sub that way no matter how good it is or how well its made. this is how the RE is rebuilt: http://www.team-bio.com/RE_rebuild.htm |
Silver Member Username: Zero43Kyle, TX USA Post Number: 137 Registered: May-05 | the only thing it doesnt show is connecting the tinsel leads |
Silver Member Username: FordpwrLos angeles, CA Usa Post Number: 320 Registered: Dec-04 | Cool , thanks guys. Sorry I couldn't respond sooner. For some reason I was getting a blank page for like 2-3 days straight. |
Silver Member Username: Zero43Kyle, TX USA Post Number: 146 Registered: May-05 | i had the same problem.... |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9255 Registered: Dec-03 | there was a DNS issue. took time for the fix to trickle down to local ISPs |
