Preout Voltage for head unit and amplifier? Help Please
Username: Kyle_allen
Post Number: 17
Can anyone explain the adjustment made by the volts on the head unit and the amp. My Alpine IVA 901 I have states that it is Pre Output Voltage (Before Clipping) : 4 V Max Min ??????, anyway, my amp range is Voltage -250mV - 6 volts. How do I adjust these setting to ge the most power? Any help would be appreciated.
Username: Jron
Post Number: 53
you should turn the gain on your amp to 4v or just a little under that. if you get distortion when you have it turned to 4v, lower it by turning the gain counterclockwise.
Username: Mlongpre
Post Number: 42
not to jack the thread or anything but what voltage is usually put out by the rca outputs on amps? i have the alpine f240 and have the outputs connected to my sub amp.
Username: Jron
Post Number: 54
you have to check the ratings of the preouts on the unit or they 2v or 4v, output is usually somewhere along there.
Username: Mlongpre
Post Number: 44
i looked for the rating in the manual...but thanks for the help
Username: Brynm
Prince Albert, SK Canada
Post Number: 57
I think the pass throughs are the same voltage as your HU
