Glass quick Qes Q
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 515
hey i couldnt find it but u said somewhere before the qes determines what type of enclosure the driver is suitable for .. what where those numbers?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8305
Qts, not Qes. :-)
Efficiency Bandwidth Product (EBP)
EBP = Fs / Qes
50 or less = best used in a sealed enclosure.
50 - 90 = flexible enclosure options.
90 or greater = best used in ported enclosure.
-OR-
Qts < 0.30 - ported
Qts = 0.30 - 0.50, use ported or sealed.
Qts > 0.50 sealed
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 301
If I may............?
I disagree.
Woofers with Qts of less than .35 are more effective in ported enclosures.
Woofers with Qts of greater than .40 are more effective in sealed enclosures.
Woofers with Qts between 35-40 are borderline, and may be used in either or... The result will be almost identical. These woofers are "Ideal".
You may choose to run your woofer in any enclosure you like, but it will cost you efficiency. I sometimes use a woofer in a lesser efficient enclosure just so I can ballance out my system. I do it for allignment/speed/frequency response purposes, not volume.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8317
you're just using more narrow guidelines than I did.. that's all.
Most people are pretty decided on the type of box they like before they start though, so it's more a matter of choosing the right sub for your application than choosing the right box for your chosen sub if it's done right.
Username: Rzarector
Post Number: 517
thx glass.. i was set on building a ported enclosure for my type x's but they have a qts of .64 so maybe id be better off with sealed
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8332
*nodnod*
