$$$ no object
Rattle
Need 2 Subs and amplifiers. Have to have excellent SPL and SQ. My wife listens to the 80's and classical whereas i listen to 50cents & CM. hehe
What subs & amps match would have me grind and pound hard that every major city block would have their windows rattling like 10 on the Richter scale??
I've heard of RE, Kicker, RF, Eclipse, Alpine, DD just to name a few but have absolutely no idea on which to settle on. Please HELP.
Remember cost no object.
Username: W00b
Post Number: 171
RE, hands down. give it a good enclosure and minimum 1200RMS, it will get loud and sound well doing it! recommended amplifiers: eD NINe.1 (www.edesignaudio.com) Orion 1200D, JL 1000/1, RF T1001BD <-- all onlinecarstereo.com
good luck with your system!
Username: W00b
Post Number: 172
also, i was talking about RE's XXX series, which was made for SQL.
rattle
triple X here i come.
What about Kicker KX1200.1? Better than the RFT1001bd & eD NINe.1?
Username: Msully701
Connecticut US
Post Number: 205
yea that would work great
Rattle
which ohm rating do i need to get for the XXX in order for me to maximise the pahwaarr amp??
i think i need 2 XXX and 2 amp eh for my set up or more than 2 amps?
Username: Terps297
Potomac, MD USA
Post Number: 130
they're dual 2 ohm so either have 2 amps at 1 ohm each or one amp at 2 ohm. look at tru-technology amps zapco, orion g4 series, ppi art series, everyone has their own oppinion but if it were my choice, i'd go with 2 12" X.X.X.'s and 2 PPI A1200.2 amps, ask anyone about the ppi art series, they will always tell you that they are no doubt in the elite class of amps.
Username: Terps297
Potomac, MD USA
Post Number: 131
if money is of no problem, i would definatley recomend a ZAPCO C2K 9.0X!! for each sub wow that would be sick.
edit:2 amps at 1 ohm [or 4 ohm] each or one amp at 2 ohm
Rattle
yeah that Zapco specs. looks great. But if i get 2 of those then I need to get 2 of the RE's XXX in dual 4ohm so i can wire it down to a 2ohm load for each of the amp eh.
btw, should d XXX be in sealed or ported enclosure? Which is best and at what volume (cufeet)?
Thanks a million Brian
Username: W00b
Post Number: 174
Brian Jackson, i would agree with you.. but i tried to give him amps that were easy to find via online retailers.. PPI art is only available on ebay unless its refurb i think.. Rattle, i suppose if you have an ebay account you should probably look at the PPI's, just make sure you know what you are doing when you hook them up!
Username: Subfanatic
Ky
Post Number: 4358
well to get the zapco amp, www.woofersetc.com has them but is not a real dealer
Username: Supraspyder420
Sammamish, Wa U.S.
Post Number: 42
If his wife listens to 80's music then he might need/want something with more SQ. two W6's or 1 or 2 IDMAX's would be good to.
Sammamish, Wa U.S.
Post Number: 43
2 IDQ15's would also be good. (im a fan of image dynamics)
Username: Hardhittinbass
Pittsburgh, Pa Usa
Post Number: 24
if u get the re xxx u would want a ported
Ky
Post Number: 4377
rattle, if your serious about having money as not an issue then do this, get 2 parthenons lol, and then get a bunch of c2k.9s to power them lol
Username: Terps297
Potomac, MD USA
Post Number: 132
your just crazy
Username: Kizzz_master
Post Number: 32
Get 2 DD9915`s n power em wiv at least 1500 each preferably more, in the right ported box you`ll get amazing bass.
