BOX NEEDED
hey i got my subs ordered and everything now alls i need is a box
2 15in Kicker CvR's im new to this stuff and am not sure whther it should be ported, sealed, or w/e... anybody willing to make and ship for under 100$ or 100$ exactly??? cuz it would be really nice
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8108
you couldn't SHIP a good box for $100
go to a local shop and have the box built.
the time it took me to write this is worth $100 to me.
how much would u charge if u were to build a box for 2 15in subs???
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8117
depends a lot on the complexity.
order/type of box, if its just a simple box of custom shaped to teh trunk of a car, what it's covered with, how it's reinforced, etc..
a box can go anywhere from $15 or $200 up into the five figure range.
enclosure material has a lot to do with the cost as well. MDF is cheap. Hardwoods and Plexiglass or Lexan are expensive.
One sheet of plexi can cost thousands of dollars.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8118
a note on shipping, I just had some artwork, framed, packaged and sent to me, and the shipping alone was over $100 for a print in a frame with glass that measured about 40"x36"x3"
That package weighed maybe 20 lbs.
a good box is bigger and weighs a lot more.
what is a bandpass box???
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8134
go here
http://www.diysubwoofers.org/
read the 4th order and 6th order bandpass sections.
they'll explain and show pictures.
typo above:
teh = the
$15 = $150
is there a program anyone has to create the dimneiosn for a box for the two 15in subs??? i know it may make me sound lazy but its ohnly because i can build it i just dont knwo how to figure otu the htz and stuff like that-- kicker says the 15in cvr needs to be at 21hz---- what is ahz anyway-- just the length of the port???
i owuld just buy one on ebay but there arrent any 3/4 mdf boxes made for dual 15 in subs
Username: Lowdose
St. Louis, Mo
Post Number: 78
Where are you located at that might help some people decide if they can help build you one.
Username: Legacyaudio
Ctown, -high-
Post Number: 49
i live in ohio
Ctown, -high-
Post Number: 50
maybe i could build u one
Ctown, -high-
Post Number: 51
are u anywhere around there cuz i kinda need the money
