Arg!
Username: Shawnomak
HB, SK Canada
Post Number: 53
my frickin car rattles so much and i found out its my tail lights and somthing under my car. There were also vents going to my door from my trunk but i took them out. Any ideas on how i can stop my lights from rattling? ALSO, what is the formula for figuring out hz for a sub box, im building one so im trying to make it sound good.
Username: Scubasteve
Annapolis, MD
Post Number: 140
Add rubber or foam around the parts of the lights that contact your car. as for finding the "hz for a sub box" i take it you are trying to make a ported box with a specific resonance frequency. It depends on port size and length.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 242
You can stop your car from rattling by turning down your volume.
Username: Shawnomak
HB, SK Canada
Post Number: 54
nah, thats not an option
Username: Iowahawks19
Post Number: 231
haha, thats cheaper too!!, and requires 2second labor(twisting of the knob)
Username: Shawnomak
HB, SK Canada
Post Number: 55
and yea, im making a vented box.. how do i make a file small enough to upload it on this site cause i have sum pics i drew on paint.
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 712
Like the man says only Solutions, play a size wave or spot frequencies at different sound pressure levels and listening for any rattles or buzzing sounds and securing the loose items.
But remember this, as the car is in motion the forces and dynamic pressures that car is going to see, those items may come undone again so constant doing the car up is a tuff thing, stop and think about the dynamic pressures the space shuttle goes though is a whole lot more a whole lot more.....
Username: Shawnomak
HB, SK Canada
Post Number: 56
application/mswordUpload
Box Measurements.doc (22.0 k)
Username: Shawnomak
HB, SK Canada
Post Number: 57
3D Box.doc (25.6 k)
heres the box in 3D, can anyone help me find the hz
Username: Tbolt
Collipark, GA
Post Number: 149
I think its tuned to about 40 hz. I used bassbox 6.
Username: Jb502
Omaha, NE
Post Number: 80
40 is high
Username: Tbolt
Collipark, GA
Post Number: 150
I know thats why Im going to recheck it.
Username: Shawnomak
HB, SK Canada
Post Number: 58
ok, and what about port displacement and sub displacement, i have 2 12" Infinity 1230's
Username: Tbolt
Collipark, GA
Post Number: 151
I fixed it its closer to 36hz.
Username: Shawnomak
HB, SK Canada
Post Number: 59
will 36 hz sound alright?
Username: Shawnomak
HB, SK Canada
Post Number: 60
So will 36 hz sound alright? the paper my subs came with said to make a ported box tuned to 30hz and for each sub to have a volume of 2 cubic feet. Are they right or will i get better results making a box my own way with rectangle vents rather than round ports?
Username: Hardhittinbass
Pittsburgh, Pa Usa
Post Number: 17
36hz is loud an hurts ur ears lol an heres a link 2 make the hz of a box go 2 the bottom 1 http://www.carstereo.com/help/Articles.cfm?id=31
