Bronze Member Username: Dtribe
Post Number: 45 Registered: Jun-05
Posted on 4 kicker CVR dvc 4ohm 10s RMS 300 and a Xtant 1001 amp that us 1000 watts stable at 1 and 2 ohms |
Silver Member Username: Iowahawks19
Post Number: 242 Registered: Jun-05
Posted on yes, you'll be SLIGHTLY underpowering them but only by 50 watts each, if the amp is underrated which i would think it is then even less good set up, tell us how it sounds |
Bronze Member Username: Kicker
Slave lake,
Alberta
Post Number: 66 Registered: Jun-05
Posted on i think she will sound good i got 12 way under powerd and they rock |
