Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 141 Registered: May-05 | Looking into 4 of these http://www.bestbuy.ca/catalog/proddetail.asp?sku_id=0926INGFS10040459&catid=2011 4&logon=&langid=EN&test%5Fcookie=1 to replace my factory speakers as well as replacing my 2 Xplod's with 2 Kicker CVR12's. The subs are powered by an Alpine-MRP350 and the HU is a Pioneer Premier 470MP. The speakers will not and cannot be amped due to something called $. Please evaluate THIS system because I can get this stuff pretty cheap which=good. Will it improve my SPL? How about my SQ? I am more concentrated on it improving SQ. Thanks! |
Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 142 Registered: May-05 | ^ |
Bronze Member Username: Dominirica012Charlotte, North Carolina US Post Number: 57 Registered: May-05 | Replacing your stock speakers with hose speakers will defenitly make your car sound better and getting rid of those sonys is also a good idea |
Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 143 Registered: May-05 | any other opinions? |
Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 144 Registered: May-05 | ^ |
Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 145 Registered: May-05 | please give me your feedback people! Are these upgrades worth it? I heard that going from the Xplod's to the Kickers would be MAYBE slightly louder, clearer (#1 reason for upgrading), DEEPER (aiming for), and more accurate (close to #1 reason). Would those be true for the most part? My trunk and car rattles like a mofo already, I don't need anything louder, just deeper, clearer and more accurate. |
Gold Member Username: James1115Wilton, Ct Post Number: 3490 Registered: Dec-04 | yes it will be better. those speakers arnt anything to brag about there is much better out there for mids and highs but as far a subs go yes that is a nice upgrade from the sony's to the Kickers. |
New member Username: ThumpinwranglerPost Number: 2 Registered: Jun-05 | KEEP THE XPLODS you said they already sound loud to make thhem sound clearer and deeper get a equalizer and cross over they will sound super clean. these people dont know what they are talking about you wont regret it. |
Silver Member Username: Mikechec9Chicago/atlanta Post Number: 248 Registered: May-05 | dude. lose the xplods. trust me. |
Gold Member Username: Jonathan_fGA USA Post Number: 4165 Registered: May-04 | Those Pioneer coaxs are a definate step up from factory speakers. The Kicker subs are also a big step up from Sony Xplods. Most important thing to remember is that the results you achieve are not just from equipment, it's the install. If your car already rattles excessively, you're better off adding Dynamat that trying to make it louder by more subs/power. It will provide better SQ as well since you're not pushing the drivers as hard to get the same effective volume. |
Silver Member Username: Iufan4lifeulLouisville, Kentucky Post Number: 151 Registered: May-05 | Due to money reasons etc. I am considering keeping my Sony Xplod's in the sealed box they are in right now and just doing the 4 seperate speakers. The Xplod's are as loud as I need them and hit the bass drum notes good, solid, deep, and clean. Would I REALLY notice a MAJOR, and I mean major difference in upgrading subwoofers? |
Bronze Member Username: Riebread77Post Number: 21 Registered: Jun-05 | Don't get an equalizer for your subs, doing so is just a waste of money as you will only use 3 or 4 of those bands due to the crossover slope...look into a phoenix gold bass cube. It will run just about $100...It will make your subs hit harder and cleaner...It has adjustable frequency choice so you can find your individual sub's sweet spot, has bass boost, and sub sonic filter...and replace the speakers...look into Infinity kappa's .7 series. Very sensitive (play loud with less power), and hit very accurate...I never use anything else...look on ebay for these things...shouldn't cost much. If you can spend everything should cost around $350...huge upgrade for little money...If you have to choose the Infinity's or the bass cube...change the interiors first...instant SQ improvement |
