Chris Brewer Unregistered guest | i don't understand why people wire their speakers down to low ohms such as 1 ohm. What is the difference between lower ohms and higher ohms and does it make any difference in sound or bass output? |
Silver Member Username: ZacdavisBeloit, Wi Post Number: 109 Registered: Dec-03 | no, do a search. Its been explained numerous times in this forum. And you will also get the correct answer faster. |
Silver Member Username: Addicted2bassMiami, Florida USA Post Number: 873 Registered: Nov-04 | simply put..more power sometimes when its lowered..less pwoer when the ohm load is higher unless you dealing with jlaudio amps |
Gold Member Username: Taylor17Kopperl, Texas Post Number: 2201 Registered: Jan-05 | Lol yup... JL is the exception to the rule. On most amps though, they will put out its full power at 1/2 ohms, then every time the ohm load doubles, the power halfs. |
Infinity_Addict Unregistered guest | people wire down to one ohm because they need the power for their subs. its not like going to one ohm makes it sound any better, its all a power issue. say you have two DVC subs that each run 400W RMS @ 4ohms. your amp puts out 400W RMSx1 channel @2ohms or 800W RMSx1 channel @1ohm. for this application you'd wire the subs in parallel and sum their wires together to get a 1ohm load because you want to give each sub 400W, like this. again, wiring is all a power issue, it has nothing to do with sound quality. |
Silver Member Username: 54danny54Post Number: 477 Registered: Nov-04 | hey infinity addict, how did u change the link 2 "this" lol, i iknow its sum html code aint it |
Infinity_Addict Unregistered guest | yah you put <a href="websitegoeshere.com">text here</a> |
Silver Member Username: 54danny54Post Number: 482 Registered: Nov-04 | <a href="www.realmofexcursion.com">Kickin<a/> |
Silver Member Username: 54danny54Post Number: 483 Registered: Nov-04 | Kickin |
Gold Member Username: InsearchofbassPost Number: 2827 Registered: Jun-04 | how did you transfer it to be kickin donny |
Gold Member Username: InsearchofbassPost Number: 2828 Registered: Jun-04 | kickin2 |
Gold Member Username: InsearchofbassPost Number: 2829 Registered: Jun-04 | sweet i realized you had the symbols backwards thanks thats a cool trick |
Gold Member Username: InsearchofbassPost Number: 2830 Registered: Jun-04 | kickin3 |
Gold Member Username: InsearchofbassPost Number: 2831 Registered: Jun-04 | mine didnt work how did you do that donny |
Gold Member Username: InsearchofbassPost Number: 2832 Registered: Jun-04 | kickin4 |
Gold Member Username: InsearchofbassPost Number: 2833 Registered: Jun-04 | sweet now i got it cool |
Silver Member Username: Addicted2bassMiami, Florida USA Post Number: 874 Registered: Nov-04 | snailshell |
Silver Member Username: Addicted2bassMiami, Florida USA Post Number: 875 Registered: Nov-04 | wow i learned something new today..lol |
Gold Member Username: InsearchofbassPost Number: 2834 Registered: Jun-04 | yup lol |
Silver Member Username: Addicted2bassMiami, Florida USA Post Number: 876 Registered: Nov-04 | <img> |
