Amp for S12L7 dual 2 ohm
Chris Brewer
what kind of amp would anyone recommend for my S12L7 dual 2 ohm if I am trying to wire it down to 1 ohm
Username: James1115
Wilton, Ct
Post Number: 3444
what the rms on those?
Chris Brewer
1500 max, 750 rms
Chris Brewer
1500 max, 750 rms
Username: Hdubb
Farmington, Nm Usa
Post Number: 1886
how much you lookin to spend young man?
Username: James1115
Wilton, Ct
Post Number: 3447
Kicker 1200.1
Chris Brewer
I was thinking somewhere below 400
Username: James1115
Wilton, Ct
Post Number: 3451
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5782523521 %26%26
Chris Brewer
I thought about the 1200.1 but it is 1200 RMS at 1 ohm and the L7 is 1500 max
Username: Hdubb
Farmington, Nm Usa
Post Number: 1890
listen to the old man. he knows.
Username: James1115
Wilton, Ct
Post Number: 3453
its rated at 12 volts. a birth sheet on it will be somewhere right around 1500 watts at 14.4 volts.
Chris Brewer
You don't think that around 900 watts over the recommended peak power is a little to much power?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1893
well your car wont do 14.4, usually. it will do about 13.8 and just be easy on the levels and what not
Chris Brewer
how did you figure that out? I thought that the rms was around half of the peak. But I didn't know you could figure out the power output by the volts it is at.
Chris Brewer
Chris Brewer
do you recommend any other amps?
Username: James1115
Wilton, Ct
Post Number: 3456
dude my bad I thought you were running two of them man I am sorry. Kicker 600.1
Username: Hdubb
Farmington, Nm Usa
Post Number: 1894
yep. i dont know the equation off the top of my head, but rough estimates usually work. so it will do right around 1350 at 13.8 volts.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1895
idk. i like headroom and if you ever want to add another id still go with the 1200
Chris Brewer
oh, all right, but i've heard that L7s sound better with more power then recommended. What do you think?
Username: Invain
Michigan United States
Post Number: 2899
MTX Thunder942
700 watts rms @ 4 ohms bridged @ 12.5 volts
Chris Brewer
Do you think that the sub is better at 1 or 4 ohms? I was told that the lower the ohms the better, is this true?
Username: Invain
Post Number: 2900
The higher the ohms the better. The amp will run cooler, and will have a better damping factor.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1896
yeah i like 4 better then 1 myself
Chris Brewer
No I mean does the sub hit harder at lower ohms?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1897
no
Chris Brewer
why do people wire their subs down to lower ohms then? What is the point? I have heard of people wiring their systems down lower than .5 ohms.
Username: James1115
Wilton, Ct
Post Number: 3457
if you have not gotten the sub already get dual 4ohm and get the kicker 1200.1. This way you will get 600 watts at 2ohms and if you ever want to add another you can wire it to 1 ohm and have 1200 watts.
Chris Brewer
It will be a while until I can save up enough money to get an amp but what kind of box do you recommend for it? I was thinking of a vented box. What do you think?
Username: Livinloud7
Post Number: 8
The reason is that when you lower the impedance, you are creating less resistance, and are allowing more power. Most ratings on subs/amps are at 4Ohms. They can be lowered, but should match impedance wise. Certain amps only go below a certain impedance level, so dont wire your system for 1 Ohms, if your amp isnt even 1 ohms stable.
Username: Chris_brewer
Stockbridge, GA. U.S.
what kind of sub do you have?
