Best Amp!
Bob Harris
What would be the BEST amp for 2 JL 10 w0's??? Let me know ASAP!
Bob Harris
http://www.jlaudio.com/subwoofers/10w0.html
thats the specs for the w0's
Username: Jonathan_f
GA USA
Post Number: 4104
JL 250/1 is a good match for them. If you want to go a little higher end you could get something from Zapco, Arc Audio, McIntosh, and the like, but it costs mucho dinero.
Connor Heming
What about for 2 JL 12w3v2's what would be best for them? Would a JBL bp600.1 work good?
Username: Thrushdtd
New York
Post Number: 68
a jbl 600.1 would work good
Bob Harris
Anything else that would be really good for the 2 JL 10w0's?
Bob Harris
I want them to hit hard... any ideas on the amp?
Username: Alias747
MN
Post Number: 230
No a JBL 600.1 will not work good. It is way overpowering those subs. If you look at the power chart on JL's site, you will see that if you hook 300 wrms up to each of those subs your gonna be voiding your warranty. In other words, it's not a good idea. Go with the JL 250/1, it is a perfect match for those subs. It's always nice to have matching brand subs and amp too. :-)
Bob Harris
anything that will still hit really hard and be reliable... but will cost a little less then the jl 250/1???
Bob Harris
GA USA
Post Number: 4111
What impedance are the subs? They come in different coil configurations.
Bob Harris
not sure..is there a way to tell.. or does it say it on the sub somewhere?
GA USA
Post Number: 4113
Should say it on the sub or the receipt from wherever you bought it.
Username: James1115
Wilton, Ct
Post Number: 3397
it should say it on the magnet like 12w0d4 or 12w0d2 something like that. we cant recomend a good amp besides the 250/1 due to its regulated power supply because we dont know the config of the vc's
Bob Harris
k will check hold on..
JL nut
no the W0s do not have dual voice coils only single
An Alpine MRD-M300/M301 will power them hard and be reliable all day long, and is very crisp in SQ it's a quality amp
JL nut
