Why don't more people use WinISD?
allende5
I'm just curious. When I first tried this app on the web, my first thought was that I wish I had something like this 10-12 years ago. It's so easy!! If you haven't tried it, check it out.
http://www.linearteam.dk/
You don't need to be an audio export, a mathmatician or a carpenter to build a very good box.
That's just IMO.
Username: Redrange
Mo Hill, California
Post Number: 87
Hey do u know the specs needed for Atlas 12. I couldnt get all them off the aa site
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1385
I use it.
Its good for comparing sub alignments to something you already know, but since its primarily designed for home audio modeling its plots can bit a decieving when applied toward the mobile audio enviroment, i.e. cabin gain isn't factord in. I wouldn't recommend using any of its suggested alignments as they may not sound good for this very reason.
The new WinISD(Pro) will allow you to get a rough plot with cabin gain by employing a linkwitz transform. If any are interested in tryin it out check this thread(copy/paste to address line):
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=11;t=072900#000000
It describes how to figure a rough aproximation of your vehicle's cabin gain and use it with a linkwitz transform in WinISD. Unfortunately only the transfer function plot(gain plot) is accurate using this method. Forget trying to predict actual in-car SPL numbers. I'm also fairly sure accuracy at sub 30 Hz frequencies is pretty limited. Still, you get a much better idea of subwoofer response in a car enviroment this way as WinISD's typical plots are limited to anechoic response(no reflections/cabin gain).
Here's a couple plots that show the differences betweeen some sealed 10" drivers in a 96 Explorer Sport.
Anechoic Response:
http://home.comcast.net/~guppyrig/wsb/media/322068/site1086.JPG
Same Drivers with Cabin Gain:
http://home.comcast.net/~guppyrig/wsb/media/322068/site1085.JPG
Pretty nifty huh?
-Fishy
Username: Fishy
Post Number: 1386
Atlas 12 specs:
http://www.ascendantaudio.com/archive/Atlas%2012.htm
Hit the buttion corresponding to the voice coil configuration being utilized, i.e. low, mid, or high Qts specs.
-Fishy
allende5
Wow Fishy...good stuff.
Username: Fishy
Post Number: 1390
Yeah its not a bad deal for a freebie.
-Fishy
