Username: Shawnomak HB,
SK
Post Number: 41 Registered: May-05
Saturday, May 21, 2005 - 23:34 GMT what are some good, cheap subs. Maybe 10's or 8's. Good sq but also spl. Dont have alot of room and its a small car. any help is great thanks
Username: Subzer0 Richmond,
KY
Post Number: 50 Registered: May-05
Sunday, May 22, 2005 - 00:10 GMT RF or audiobahn.. are really cheap.. and ok thumping for their pricetag, check ebay <-- you can get some 8"s for less than 20 dollars.
Username: James1115 Wilton,
Ct
Post Number: 3158 Registered: Dec-04
Sunday, May 22, 2005 - 01:45 GMT you can get Resonant engineering RE 8's for $40 they sound nice and will get loud for 8's
Username: Alastaka Post Number: 31 Registered: May-05
Sunday, May 22, 2005 - 03:06 GMT i like rockford stuff id go with p2's i had 2 p'1s and they were loud in the truck but tht was it the p2's are twice as powerful i believe and shouldnt cost more then 70 a pair on ebay for 10's but it depends on what amp your running too. what kinda space do you have to work with
