4 channel Amp and subwoofer
I have 4 channel Amp. I wan to hook up all the radio speaker and an Infinity 10 inch 1000 Watts 250 rms woofer to it. I have (4) 400 watts max speaker The amp is 1600 watts any ideas. I have a pioneer cd/mp3 radio no sub out
Username: Hurleyblink
Post Number: 17
yeah hook up all the speakers and run the sub trimode on 2 of the channels. front or back channels 1 - 2 are hooked up with 1 speaker each. then back 2 channels are hooked up the same way but you add the subwoofer (bridged) with a low pass crossover inline with the sub.
