compEngineer0 Unregistered guest | i'm looking to buy two 10" Kenwood KFC-W2509 subwoofers, but i'm not sure what amp i need to pair with it. do i need a 2-channel or a multichannel? any and all recommendations are much appreciated. |
Bronze Member Username: Mr_wiglzManchesterEngland Post Number: 28 Registered: May-05 | you don't even need a two channel. One channel sub amp would be fine. I don't knoe the specs but as an example I will say thy're about 400 watts rms and 4 ohm impedence. So, you need an amp that is 800 watts rms @ 2 ohms why 2 ohms, because you wire the subs in parallel to eachother wich drops the impedence down to 2 ohms. so you connect the subs together and plug them into the amp. I dunno how to insert images here, but I'm sure someone will help you out. whats your budget? |
compEngineer0 Unregistered guest | subs: 10", 4-ohm power range 35-350 watts RMS peak power 700 watts my budget isn't too much. i've been picking out pieces on crutchfield.com and i'm at about $600 for receiver, subs, box, front and back speakers. can't spend too much more on an amp, but then again i do need one. probably lookin to spend under $200 and as close to $100 as possible |
compEngineer0 Unregistered guest | well, with the info you've given me, i'm looking at an audiobahn A8000T amp: 800 watts RMS x 1 at 2 ohms for $300. sound about right? either this or i might just go with one 12", seems a little cheaper that way... |
compEngineer0 Unregistered guest | or an Kenwood KAC-9102D amp: 850 @ 2 ohms for $300 |
Bronze Member Username: Mr_wiglzManchesterEngland Post Number: 31 Registered: May-05 | if they're 800 0r 850 watts RMS at 2 ohms then it's fine. Check on ebay also dude, you could find them on there for half the price. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5774692164 &tc=photo http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5774692164 &tc=photo |
Gold Member Username: InsearchofbassPost Number: 1962 Registered: Jun-04 | im not a kenwood fan sub wise but id do one 12 instead of two 10s it will prob hit just as hard and play a little lower frequency wise which would be good for music plus you have more flexability to make a larger box size if you need to |
compEngineer0 Unregistered guest | cool, thanks for all the help |
Gold Member Username: InsearchofbassPost Number: 1963 Registered: Jun-04 | are you going to be building your own box? |
