W6v2 vs. w7
Username: Mcazayoux
New roads, La United states
Post Number: 130
i think iv heard that the w6 has significantly btter sq but how else do these compare?
Username: Loc_out
Post Number: 110
If you want sq go with the w6v2 if you want spl then go with the w7.
Username: Subfanatic
Walton, Ky
Post Number: 3252
the w7 sounds horrible TO ME!, not to everyone, the w6v2 is like a work of art. lol
Username: Mcazayoux
Post Number: 131
lol thanx. i think im gonna go with the w6 but my friend is getting them so i was thinkin about the w7. i dont like to look like a follower.
Walton, Ky
Post Number: 3257
haha, the w7 will be louder though, but why dont you get somen cheaper instead, like a Ti?
Username: Shekei
Post Number: 33
or if you wanted to get 2 w6's and it would beat one w7
750 watts vs 800
Username: Mcazayoux
Post Number: 132
im talkin about gettin 2 w7s? and hey sub, how do the Ti and JLs compare in both sq and spl? thanx
Username: Fordpwr
Los angeles, CA Usa
Post Number: 206
They are both great subs but I myself would go with an 15" or 18" x.x.x. Alot louder than the ones yoou've mentioned ,awesome SQ and SPL(with a good amp of course and enclosure).
Username: Mcazayoux
Post Number: 133
thanx dr max but i dont think i can fit anything bigger than a 10 under the seat of my 99 f150 ext. cab
the seats dont come too far off the ground
Username: Phrozen1der
how do they compare to the kicker solo x 12"
Username: Mcazayoux
Post Number: 134
how does what compare to the solo x?
the w6's or w7 cause i was looking at getting those but i can get 2 solo x for 440
Username: Mcazayoux
Post Number: 135
well that is a great price, but the sound quality doesnt even campare to either of the JLs. now iv heard the w6s have the best sq and the w7 hits a little harder. that solo x should hit though depending on your amp[s].
yea i was looking at the kx2500.1 one amp for each sub. it would cost me about 900 for both and even though i can get an accommodation through kicker i want what would sound better.
