Which amp should I buy?
Username: Mike318ti
Hey Guys!
I just recently purcahsed:
Two Audiobahn AW102T Natural Excursion 10" Subwoofers
Specs-
Impendance: 4 Ohms
Voice Coil: Single
Sensitivity: 92.3dB
450 Watts RMS
I have a 1995 BMW 318ti and i'm looking to build a box similar to this on each side on the hatch,
What kind of amplifier would you guys recommend I buy for this setup.
PS: I'm not looking to spend more than $300 on the amp. Preferably something in the $100-250 range.
Thanks,
-Mike
Username: Carguy
Post Number: 2237
You can try Orion HCCA 250G4, PPI PC/PCX series, MTX and Audiobahn A8000T ($130).
Username: Mike318ti
Thanks Isaac,
Would you happen to know a good reliable website that sells those amps?
-Mike
Username: Carguy
Post Number: 2244
eBay should have them all. 250G4 and PPI PC/PCX series are time limited items. So if you don't buy now, they might not be available later.
