Are SPL amps any good?
Username: Alexochoa
Tucson, Arizona USA
Post Number: 9
there are SPL amps on ebay going for $150
RMS @ 4 Ohms: 310 X 2
RMS @ 2 Ohms: 370 X 2
RMS Mono: 740
Full Mosfet Power Supply
PWM Circuitry
2 Ohm Stable Stereo
Tri-Mode Capable
Variable Low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5Khz
18dB Bass Boost @ 40Hz.
Frequency Response: 10Hz to 30Khz
S/N Ratio: 97 db
THD: 0.02%
I Have Infinity Refrence 12" subs, think this will sound good?
Power Handling, RMS: 300 Watts
Power Handling, Peak: 1200 Watts
Sensitivity: 92dB
Frequency Response (±3dB): 20Hz - 250Hz
Mounting Depth: 6-7/16"
Impedance: 4 Ohms
or would this amp be better with ONE Type-R??
Thanks for your input.
Username: James1115
Wilton, Ct
Post Number: 1125
no
