Eclipse Aluminum, VAS question
Username: Invain
Michigan United States
Post Number: 559
I'm looking at getting the SW7100 series Aluminum 12", but I noticed the SW7300 series has almost the same specs. The only real difference between the 7100's and the 7300's is that the 7300's have a larger vas. I know vas has to do with the suspension, but what's the difference between these subs? Which is better?
Username: Dankman
Granger, Indiana United States
Post Number: 35
I have the eclipse SW7124DVC T-2 and its very loud i think it is better than the 7300s but yea they are great subwoofers get them off www.woofersetc.com for 209.99 for the SW7124DVC T-2's they are good SQ/SPL subs, go ported with them also they sound great ported.
Username: A3forme
Post Number: 331
Joe - The basket design is completely different between the two. But all other specs are same except the Vas. Sorry though, can't tell you what Vas is...
Username: Invain
Post Number: 565
Yeah. I downloaded the tech file on the subs and the sw7100's have bigger magnets, and they do look different. I just wondered what exactly Vas was.
Username: A3forme
Post Number: 333
So which one is really better? Or do they serve diff. purposes?
Username: Invain
Post Number: 566
I think they serve diff. purposes. I'm just gonna take a leap and say that the 7100 has better spl, but who knows. I need Jon or Isaac or somebody to tell me what Vas is.
Username: Jonathan_f
GA USA
Post Number: 3230
Vas is the equivalent suspension compliance of the subwoofer, meaning that if a sub has a Vas of 2 cu ft, then the suspension provides the amount of pressure that 2 cu ft of air would. It has more to do with choosing the right enclosure than it does the SPL of the sub. You'll need to know other factors as well, more magnet doesn't necessarily mean a better sub, huge magnets can tend to overdampen the driver if they are too strong for the sub they're powering, it can result in a boomy sound.
Username: Invain
Post Number: 574
Ok. Thank you Jon. Somebody finally answered me.
