Username: Xxkmfdmxx St. Petersburg,
FL
Post Number: 312 Registered: Oct-04
Wednesday, February 09, 2005 - 22:25 GMT I just purchased two Elemental Designs 13Kv.2 Dual 2 ohm subs, Was wondering if a JBL 600.1 amp would be good enough for them?
Username: Carguy Post Number: 1454 Registered: Nov-04
Wednesday, February 09, 2005 - 23:37 GMT You'll need 1000w rms amp. Try JBL's 1000w model, JL 1000.1, Orion, and PPI.
FL
Post Number: 313 Registered: Oct-04
Wednesday, February 09, 2005 - 23:57 GMT ..There 350W rms though the 13kv.2's. why 1000 rms? Thinking of the OV.2's maybe? Their 600w RMS each. IF I wire the subs to 2 ohms The Jbl should put out atleast 600w(Someone told me it could put out upto 800w at 2 ohms but dont know if thats true)
Username: Carguy Post Number: 1461 Registered: Nov-04
Thursday, February 10, 2005 - 02:07 GMT Oh ok, I thought they were 600w rms. In that case JBL 600.1 amp will do just fine.
Username: Help_2 Post Number: 56 Registered: Dec-04
Thursday, February 10, 2005 - 02:48 GMT You can put 500w on one 13Kv2 no problem... Theyll sound just fine on a 600.1, although you might want to consider a larger amp.
FL
Post Number: 314 Registered: Oct-04
Thursday, February 10, 2005 - 13:22 GMT Yeah, Maybe sometime in the future, I was just getting the JBL amp at such a great price, Figured I'd get it.
