I am geting a new system. have a MAXX of 1000 to spend i have already decided on an amp a JBL1200.1 and then i need some subs i will make the encloser for them. I want a high SQ and i want it to have a very good SPL.I like playing it loud and clear but i want to spend as little as posable on it just becouse im tight on money. for me i will be installing it all to.Thanks for any help.
Help
So by system.... do you mean the whole works... or just subs and an amp?
front speekers and subs i already have an amp for it.
well buddy take a look at the jbl1200.1 its a goofy amp its rated mono but set up as a 2 channel...id go with something jl or perhaps kicker...ive had no problems with either and pretty happy with my products.
