SUV Cargo Area Placement?
Username: Sirfishalot
Seattle, WA USA
Currently I have my JL Audio CS308R-w0 placed facing the rear window in the cargo area of my 2dr Yukon. My question is if there is any differnce in sound as to how the subs are facing; sideways, back or front? I could probably set it on the floor right behind the front seats facing foward. Any thoughts?
Thanks
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 167
placement does make a difference, but its trial and error. Just take your time and see which place is the best.
Username: Pat_l
Tucson, AZ USA
Post Number: 656
exactly, every car is different, you wont know until you try. So flip and turn your box around, sit in the drivers seat and trial and error till you get the best sound up front.
