Can you hook up a power amp and a receiver together to get both pumping power at the same time to the same set of speakers. If not, how can you get more power ontop of whatever you already have?
Greg Lee
No. If your receiver has preamplifier outputs, you can plug them into an amplifier that supplies the power you want (then the amplifier in your receiver will not be used).
