Bi-amping my B&W 684, combining NAD and Rotel amps...
Username: Attndef
So here is my set up. Currently I have a NAD C740 (30 watts per channel) receiver running to my B&W 684's. I just purchased a Rotel RB-1050 Power amp (70 watts per channel) on Ebay and got a good deal on it to. I was looking to horizontally bi-amp this set up with the Rotel going to to bottom end and the NAD to the high. I just have a few questions: Am I going to run into problems because the amps are different brands or gain? Could I be better off bridging the two amps or just using the NAD as a pre-amp?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 2186
I would use the NAD as a pre, and use the Rotel to drive your speakers. Bi-amping with two different brands will be problematic. The NAD and Rotel have different sonic signatures (and probably different gain levels). It'll be a mess.
Username: Attndef
I was thinking that might be the case..I will give it a try in both configurations and give it the head to head listen of course. I was just wondering what to look out for or if anyone had any experience with trying anything like that.
Username: Nuck
Post Number: 11663
A 'mess' seems appropriate.
Username: Nuck
Post Number: 11674
Just use this?
http://www.canuckaudiomart.com/details/119129-bryston_14b_in_black/
