Need a little help
Username: Okeefester3
Hi, I had the cable guy here this morning for something different but he showed me where to hook my audio cables to to hook my stereo speakers into my cable box.
I had cables so once he left (first mistake) I decided to hook it up. Red and white out of cable box into AUX input on receiver...simple.
Hmmm...well if one (red or white) is hooked up I can get sound out of one speaker but as soon as I hook the other in it muffles and fades out the sound to nearly nothing in both speakers. I cannot figure this out...both speakers work but they wont work at the same time :-(
I tried 2 different sets of cables and the same thing happened with each.
Anyone know why this might be happening?
Thanks!
Username: Frank_abela
Berkshire UK
Post Number: 3434
Weird indeed! Your cables have a red and white connector at each end right? So they should be going into a red and white (not yellow!) socket on each side. Ensure you're not going into a yellow socket because that's meant to be a video signal. Not sure what else to think of, sorry.
