New Monitor Audio Platinums
Username: Patrickbateman
MA
Post Number: 46
<http://www.widescreenreview.com/news_detail.php?id=12512>
December 28, 2006
Monitor Audio Raises The Bar With The Introduction Of The Flagship
Platinum Range
Platinum loudspeakers are a sophisticated blend of craftsmanship and
science created from the finest materials and leading-edge
technologies. The challenge for Monitor Audio's design team was to
achieve the most natural sound possible by focusing on every detail,
however small or seemingly insignificant. Unique materials and a
purist design approach have transformed our loudspeaker performance
to another level, setting the benchmark for all others to follow.
The new Platinum range is the epitome of British craftsmanship,
quality, and Monitor Audio's award winning sound. Finally, every
speaker is carefully hand assembled in England and tested in our
anechoic chamber to exacting standards.
Platinum C-CAM Ribbon Tweeter
Our ribbon design uses an ultra-thin enforced sandwich of C-CAM
(Ceramic-Coated Aluminum Magnesium) alloy suspended in a powerful
transverse magnetic field of high-energy NeFeB rare earth magnets.
The ribbon serves as both voice coil and radiating diaphragm, with
every part of the ribbon driven directly and simultaneously without
energy storage. This means the Platinum ribbon tweeter provides very
fast transient response and is able to start and stop in an instant,
perfectly reproducing the leading edge and natural decay of complex
musical sounds and their harmonics. The ribbon is capable of
ultra-wide bandwidth with a useable frequency response to 100 KHz
and is more than capable of producing sounds and all harmonics found
in today's hi-def wide-band formats, such as DVD audio, SACD, Blue
Ray, and HD-DVD.
Platinum RDT (Rigid Diaphragm Technology) Mid-range and Bass Drivers
A core of honeycomb Nomex material is sandwiched between ultra-thin
skins of C-CAM alloy. These skins are only 40uM thick or less than
half the thickness of human hair. Platinum RDT cones are
approximately 150 times more rigid than conventional, single-layer
aluminum alloy cones. The hexagonal honeycomb core is the most
effective shape to maintain structural rigidity when used in a
bonded laminate composition, being ultimately more rigid than a
solid structure and possessing a fraction of the overall mass. The
aim is to reduce mass and increase cone stiffness so the cone works
as a lightning-fast piston. The new concave cone geometry, refined
by FEA analysis, provides smooth frequency response and eliminates
high frequency break up. Other applications of similar composite
construction techniques are used in high-performance aerospace and
automobile racing applications such as, fighter jet flooring to
Formula One racing components. RDT is a unique design, developed
specifically by Monitor Audio for the Platinum range.
Platinum ARC (Anti-Resonance Composite)
The front baffles, mid-range enclosures, and plinths of Platinum
loudspeakers are made of a cast Anti-Resonance Composite material.
ARC is a cast thermo-set polymer loaded with minerals to provide
very inert, optimally damped components. This type of material is
used in high-tech automotive applications and is ideal for high-end
acoustic applications where ultimate structural rigidity and
vibration damping is required.
Platinum TLE (Tapered Line Enclosure)
A special tapered parabolic shaped enclosure with a cast ARC front
baffle is designed to prevent standing waves and modal resonance.
The enclosure's tapered shape, together with the use of graduated
damping materials, serves to attenuate upper-range frequencies.
All cabinets are built using multiple laminations of wood veneers
and shaped to form a rigid one-piece shell, which provides extreme
rigidity. Internal enclosure walls are non-parallel to prevent
standing waves. A unique 'pin-hole' internal bracing structure
provides additional cabinet integrity. Steel bolts tie front and
back panels to this 'pin-hole' structure to further enhance cabinet
bracing. Finally, Bitumastic damping material is applied to all
internal cabinet walls to provide a further level of resonance
damping.
Platinum HiVe2 (High-Velocity) Ports
Platinum loudspeakers feature new HiVe2 port technology that uses a
straight rifled design to accelerate airflow and reduce turbulence.
HiVe2 ports have the ability to move air in and out much more
quickly than conventional ports, resulting in fast and powerful bass
with superior transient response.
Platinum Terminal Panels and Alloy Spiked Feet
Platinum loudspeaker terminal panels are finely machined and plated
with pure platinum, providing the best possible contact reliability
for cable connections. The terminals feature accurate Micrometer
adjustment and are suitable for heavy-duty cables with spade, 4mm
plug, or bare wire connection of all types.
Machined alloy adjustable spiked feet are used on the PL300, and
PL100/ PL350C floor-stands. The feet are meticulously machined from
high-grade alloy and anodized to exacting quality standards. Solid
'bullet' spikes are also hand machined from hi-tensile steel and
chrome plated to a mirror finish. For hard or solid wood flooring, a
non-slip rubber pad is integrated into the foot design.
C-CAM
Our renowned C-CAM (Ceramic Coated Aluminum Magnesium) alloy is an
innovative material that exhibits ideal mechanical properties for
use in high performance loudspeaker cones and diaphragms. C-CAM is
extremely rigid and light, resulting in accurate sound reproduction
and high overall efficiency. The C-CAM material is utilized in the
construction of Platinum ribbon tweeters and RDT mid-range and bass
driver cones.
Strathspey Leather Front Baffles
The front baffles on Platinum loudspeakers are hand-upholstered
using Strathspey leather. Strathspey is the best quality natural
leather available and is used in exotic furniture, automotive, and
marine applications for the most quintessential British products.
Strathspey adds a warm, tactile feel and provides a traditional,
high-quality furniture appearance, allowing Platinum speakers to
blend easily into any décor.
Piano Lacquer Santos Rosewood and Ebony Wood Finish Options
Platinum loudspeakers are available in hand-selected, piano lacquer
Santos Rosewood or Ebony wood veneers. The wood veneer is
hand-applied using traditional furniture techniques, ensuring
precise grain matching and no joint visibility. Then, eleven layers
of clear gloss piano lacquer are applied.
The Models
Platinum 100
The PL100 is a compact two-way loudspeaker featuring one 6.5-inch
RDT bass-mid driver and a C-CAM ribbon tweeter. The PL100 produces
superior bass definition and articulate mid-range akin to the most
accurate studio monitors. The extraordinary PL100 has the ability to
reach bass frequencies previously unattainable in such a diminutive
package. PL100 dimensions: 14? x 8 x 11? inches (HxWxD)
Optional, dedicated floor stands are available which can be bolted
directly to the PL100 cabinet for increased stability and
performance. The PL100 stand allows an increased level of tilt to
enable optimum set up and positioning. The PL100 Stand is 24-inches
tall.
Platinum 300
The PL300 is a three-way floor-standing loudspeaker featuring two
8-inch RDT bass drivers, one 4" RDT mid-range driver, and a C-CAM
ribbon tweeter. The PL300 is a true wide-bandwidth speaker system
and is able to cover an astonishing frequency spectrum from 28Hz--100
KHz.
The RDT mid-range driver is dedicated to producing frequencies
between 550Hz and 4 KHz with extreme ease and clarity, thanks to its
ultra-light RDT cone. A special, bullet-shaped ARC mid-range
enclosure provides an inert and well-damped chamber that is designed
to prevent standing waves.
PL300's crossover is mounted in the cast ARC plinth to eliminate
magnetic interference and provide acoustic de-coupling from the
speaker itself. The ARC plinth also houses the bi-wire speaker
terminals and provides convenient floor-level access. PL300
dimensions: 43? x 11? x 14? inches (HxWxD)
Platinum 350 Center
The PL350C is a 3-way, four-driver center channel speaker featuring
the same driver compliment as the Platinum 300 Floorstanding
Loudspeaker. The PL350C has the ability to reproduce frequencies
from 32Hz--100 KHz, making it one of the widest bandwidth center
speakers available. Like the PL300, the PL350C's RDT mid-range
driver operates in its own ARC mid-range enclosure. Neutral tonal
balance and sound that is clear from any kind of distortion or
resonance makes it perfect for reproducing crystal clear dialogue.
More than 60% of the total sound balance in a theater system is
funneled through the center channel, that makes it all the more
important to make sure it's up to the job. But just as important,
the speaker must be capable of matching the bandwidth and dynamic
range of the front/main speakers in the system. Performance and
tonal balance from the PL350C is matched to the PL300 and PL100,
which makes it the ideal center speaker choice when building a
Platinum multi-channel audio/video system.
An optional PLC Stand is available to provide straight or tilted
positioning. The twin-pillar PLC Stand is 13?-inches tall.
The Platinum Range will be available in May 2007.
MSRP:
Platinum 300: $8,995.00 Pair
Platinum 100: $4,295.00 Pair
Platinum 350C: $4,295.00 Each
Platinum 100 Stand: $695.00 Pair
Platinum PLC Stand: $495.00 Each
About Monitor Audio
Monitor Audio designs and manufactures British loudspeakers and
music systems of the highest quality. Since 1972 Monitor Audio has
been at the forefront of loudspeaker technology, perfecting the
implementation of metal drivers. It is renowned for exemplary
speaker cabinet construction and finish.
Kevro International Inc. is the exclusive distributor of Monitor
Audio products in North America.
To find out more about Monitor Audio see www.monitoraudiousa.com.
Report Post
Username: Jan_b_vigne
Dallas, TX
Post Number: 9574
OK, why'd you post this here?
MA
Post Number: 47
new speakers, thought someone might be interested
Username: Stefanom
Silver Spring, MD United States
Post Number: 269
I love marketing... Platinum HiVe2 Ports sounds pretty darned impressive. I wonder, Tim do you have any plans to implement this revolutionary technology in your speakers?
