What 135W or a bit more amplifier do you like?
rmihai
My budget is limited to US$1100.
Thank you
Username: Nuck
Parkhill, Ontario Canada
Post Number: 1406
5 x Outlaw monoblock m200's @1225 for the lot.
rmihai
I only need a stereo Power amp for music.
And used. And under US$1100.
Username: Nuck
Post Number: 1411
rmihai, do you require an amp(do you have a pre-amp) or an integrated?
Username: Project6
Post Number: 6273
It has to be "used"???
Username: Nuck
Post Number: 1417
'previously enjoyed'
It was traded for a reason, although this is different than cars.
Username: Gman
Mt. Pleasant, SC
Post Number: 839
Go to audiogon.com They have lots of used stereo amps posted that will fit your needs.
