Dynaudio Audience 52 Setup Help (Hawk/ Rick)
St. Louis Blues
Rick/ Hawk- Just received my new Audience 52's. Wondering your thoughts on setup settings w/ my Nad T763 / A52's / Polk Subwoofer. Currently have my receiver set to small- w/ x-over settings at 80 Hz. What do you guys think about this setup? Would you change things around?
Thanks ahead of time for your help!
Username: Rick_b
New york Usa
Post Number: 191
SLB,
Congrats! Are you currently using the system as a 2 channel stereo, or 5.1 (6.1)? 80Hz is a good starting point. How does it sound to you? I am old school and tune by ear. Keep adjusting until the cross-over and gain give you the best blend between sub and speakers. Cheers!
St. Louis Blues
Thanks Rick- Setting it up as 2 channel for now- while waiting to pick up a 122C center. Eventually will upgrade the sub/ add 42's as rears.
Started out with it set at 80- sounds good so far. Will dial it in with my spl meter this weekend.
So far, they sound really good.
Dino
The 52SE Special Edition are already out. Have you guys auditioned this new speakers. Any significant difference with the 52s.
