Question about wiring subs
tristan
if got 2 300W 10" subs and a 400W amp, would it be better to do series or parallel wiring
Username: Bmw325is
Post Number: 12
I would say parallel since in a series i would think 300 watts of the amps would go to the first sub and only 100 to the second but i am not positive on this.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1436
Car forum please. And Kevin is unfortunately wrong about how electrical load works.
Username: Jan_b_vigne
Dallas, TX
Post Number: 5902
kb - Here's a start on understanding what happens.
http://www.bcae1.com/spkrmlti.htm
Username: Dubking
Vancouver, BC Canada
single four ohm, series parellel as long as the amp is 2 ohm stable
hi
i have 2 12 DUAL VOICE COIL SUB 1200W
12" subwoofer
4 Ohm Impedance
2.5" Dual Voice Coil
60+60 Oz. Magnet
1200 Watt Rated Power
AND 1 lenzer VIBE 261
2400 Watt 2 Channel MOSFET Amplifier
1200 WATTS X 2 STEREO
2400 WATTS X 1 MONO
2 OHM STABLE, TRI-MODE CAPABLE
BUILT IN HIGH & LOW CROSSOVERS
VARIABLE BASS BOOST
REMOTE SUBWOOFER CONTROL
i how do i connect subwoofers to that 2 chanel amp to get best quality bass
Dallas, TX
Post Number: 5977
Go to the car audio section of the forum.
