New member Username: Mustang23Mattawan, Michigan Post Number: 1 Registered: Jul-04 | wat size amp would i need for 2 12 inch subwoofers? wat size amp would i need for 2 10 inch subwoofers? if you have an answer please email me at lilplaya1623@aol.com |
Silver Member Username: Davids2004Houston, TX USA Post Number: 302 Registered: Jun-04 | All depends on the rms wattage of the amps and then that will depend on how you can wire the subs. Need more specs. Need rms on the subs and then if they are dvc or svc and how many ohms are they then we can answer it a little better. |
New member Username: Mustang23Mattawan, Michigan Post Number: 2 Registered: Jul-04 | The XS-L121P5 12" subwoofer handles up to 350 watts RMS, and works well in sealed or ported enclosures. Key Features: five-sided polypropylene cone rubber surround frequency response 18-2,000 Hz power range 90-350 watts RMS peak power handling 1200 watts sensitivity 89 dB top-mount depth 6-5/16" sealed box volume: 1.0 cubic feet ported box volume: 1.58 Recommended Q-Logic Box Type: 1, 3 1-year warranty |
New member Username: Mustang23Mattawan, Michigan Post Number: 3 Registered: Jul-04 | The XS-L121P5 12" subwoofer handles up to 350 watts RMS, and works well in sealed or ported enclosures. Key Features: five-sided polypropylene cone rubber surround frequency response 18-2,000 Hz power range 90-350 watts RMS peak power handling 1200 watts sensitivity 89 dB top-mount depth 6-5/16" sealed box volume: 1.0 cubic feet ported box volume: 1.58 Recommended Q-Logic Box Type: 1, 3 |
Bronze Member Username: LoudnobnoxiousPost Number: 39 Registered: Jul-04 | sony is not the way to go in car audio. please someone suggest this man something that is around the price of the sony p5 but cheaper. im lazy. |
New member Username: Mustang23Mattawan, Michigan Post Number: 4 Registered: Jul-04 | wats tha way to go then give me your suggestion |
Bronze Member Username: BdonkersgoedOntario Canada Post Number: 17 Registered: Jul-04 | I think Alpine is supposed to be awesome for head units (I really like mine!) As for subs, I am getting an Alpine Type R, altough there are other brands that may be better (but more money). I am getting the 10" Type R on Ebay for $75US plus $35US shipping. It is a 300W RMS 4ohm DVC Not too bad ![]() Hope this helps a little ![]() Regards, Bryan |
Bronze Member Username: BdonkersgoedOntario Canada Post Number: 18 Registered: Jul-04 | I think Alpine is supposed to be awesome for head units (I really like mine!) As for subs, I am getting an Alpine Type R, altough there are other brands that may be better (but more money). I am getting the 10" Alpine Type R sub on Ebay for $75US plus $35US shipping. It is a 300W RMS 4ohm DVC Not too bad ![]() Hope this helps a little ![]() Regards, Bryan |
Silver Member Username: Davids2004Houston, TX USA Post Number: 304 Registered: Jun-04 | How much do you want to spend. |
New member Username: Mustang23Mattawan, Michigan Post Number: 5 Registered: Jul-04 | all together for amp plus subs no more than 600 |
Silver Member Username: Davids2004Houston, TX USA Post Number: 312 Registered: Jun-04 | Here you go. 2 dayton quatro 10s-www.partsexpress.com and search for them Xtant A3001T-130-150.00 shipped off ebay. Total under 300.00 for amp and subs. |
Silver Member Username: Davids2004Houston, TX USA Post Number: 313 Registered: Jun-04 | Or instead of the dayton quatros you could do. 2 Xtant Z104-www.sounddomain.com -90.00 shipped for both subs with the same amp So with that setup less then 250.00. |
