Silver Member Username: Cplaya280Quakertown, PA USA Post Number: 436 Registered: Oct-05 | I'm getting a 2002 Mitisbishi Galant and was wondering if i HAVE to upgrade my alternator cuz i know right now it has 3.0 L V6 and the stock alternator is 85A. If i do need a new alternator what are some good sites to find some i tried to look on Iraggi for a galant alternator but i cant find any at all. I have 2 Kicker 12" l7s with the kicker zx1500.1 amp which says it does like 1769 watts. |
Silver Member Username: SkiesCourtenay, British Colu... Canada Post Number: 700 Registered: Aug-05 | If you have it all hooked up already, do your lights dim quite a bit? Are they quick to get back up to standard brightness? Do your big 3 upgrade first, and see how your voltage does then. If its still dropping a lot, then upgrade your alternator. Contact Iraggi and ask him if he can make one for your vehicle, or contact Nate at Excessive Amperage. |
Silver Member Username: Cplaya280Quakertown, PA USA Post Number: 437 Registered: Oct-05 | not hooked up yet but just wanna be prepared cuz i used to have a 2002 impala the alternator was 105A and those lights dimmed like crazy and the galant is 85A so thats why im asking if its gonna kill my alternator |
Silver Member Username: Cplaya280Quakertown, PA USA Post Number: 438 Registered: Oct-05 | i forget what the big 3 is i thought it was Alternator,Battery,Capacitor |
Silver Member Username: Cplaya280Quakertown, PA USA Post Number: 439 Registered: Oct-05 | is there any other alternators besides Iraggi and Excessive Amperage |
Gold Member Username: BernymacCambodian Post Number: 2703 Registered: Sep-04 | Iraggi and EA will be your best choice. Theres other companies out there but "I" don't know if you're willing to pay that type of price. Big 3 is. Alt To batt + Batt - to car chassis Engine block to car chassis |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2588 Registered: Jul-06 | "i forget what the big 3 is i thought it was Alternator,Battery,Capacitor" I'm sorry but that seriously made me laugh out loud ![]() Big 3 is upgrading the WIRING from the things that Berny listed above. |
Gold Member Username: BernymacCambodian Post Number: 2705 Registered: Sep-04 | haha yeah I forgot to say wiring. My bad =). |
Silver Member Username: SkiesCourtenay, British Colu... Canada Post Number: 704 Registered: Aug-05 |
Hahaha that was good :P Definitely do your big 3 right away, and then see how your voltage is after that. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2425 Registered: Jul-06 | I recommend you email Dom at Iraggi and ask if he can build an alt for your car. Failing that, I would recommend contacting www.ohiogen.com . They make the best quality alternators out there, but they have price tags to match. |
