Silver Member Username: KravenbloodOhio Post Number: 145 Registered: Aug-05 | debating weather or not to spend this much on an amp..Which one would you get? dd z1 1500 through dd bpx2200.1 1300 at sounddomain.com |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 2281 Registered: Jan-06 | probly worth the extra 200 for the z1 its a sweet amp, just keep in mind other electical upgrades |
Gold Member Username: BernymacCambodian Post Number: 1351 Registered: Sep-04 | z1 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3686 Registered: Dec-05 | z1. Power wise |
Silver Member Username: KravenbloodOhio Post Number: 146 Registered: Aug-05 | i got an 180 amp alt biggest i could find for my car and a kintetic battery the cap killer anyway and im going to see if the hc1400 fits in my stock location..and according to dd the z1 its made to run off a stock electrical system but anyways.i like the jbl cause of the fact same power through 1 to 4 ohms so i can change my set up and not worry about it. i dont know thoug a rf bd2001 is cheaper than them both lol |
Silver Member Username: Sinful_systems70Post Number: 178 Registered: Nov-06 | I concur!!!!! DDZ1![]() |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 240 Registered: Mar-06 | Well with the Z1, they are getting 4200-5000+rms at 1 ohm hehe. VERY efficient and at 4 ohm, is clean as class A/B amp. DD is way to go. Kevin PS: Shoot me an email Kevin, lowhz01@yahoo.com |
