New member Username: Sttt24
Post Number: 2 Registered: Jul-06
Posted on are there any good amps that actually put out 1000rms X 1 @2ohm |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 8664 Registered: Jul-05
Posted on JBL GTO1201.1 |
Gold Member Username: Dustin3
Tigard,
OR
U.S.
Post Number: 2714 Registered: Oct-05
Posted on zx 1000 |
Gold Member Username: Juliob
Santo DomingoDominican Re...
Post Number: 1376 Registered: Dec-05
Posted on yeah, check kicker or JBL. Also PG xenon 1200.1, JL 1000-1. Also you can strap amps to the DVC, but you'll need 1 ohm stable amps. |
Bronze Member Username: Allstar0087
Post Number: 11 Registered: Jun-04
Posted on i'm a believer in hifonics |
Tigard,
OR
U.S.
Post Number: 2721 Registered: Oct-05
Posted on ^^ not as 2 ohms though  |
Post Number: 1406 Registered: Dec-05
Posted on that's right... check rockford X6 ot X7 they're good |
