Subwoofer Questions
Username: Audio_newb
Post Number: 11
Ok, i have a soundstream xtream 880.2 I was wanting to know if it would be good enough to push 2 12 inch kicker CVR's? or any other recommendations would be also nice
Post Number: 12
bump
Username: Stnorris
Eldridge, IA US
Post Number: 659
ya i heard that soundstream pushes out true watts. i cant find the specs for that amp, but if you can get it to push at least 800rms, it will work good with 2 cvrs
Username: Kaerfpl
Spencerport, NY USA
Post Number: 209
Which CVR's are they? The dual 4ohm VC or 2ohm VC? Either way, I don't think you will be able to power them unless that amp can go as low as 1ohm when bridged which I don't think it can... You can power one CVR if it's the dual 4ohm VC though.
Do you have to have two subwoofers? Theres a lot of subs out there that anyone could suggest for you. For one, what's your budget? For two, what are you looking more for, SQ or SPL?
Username: Kaerfpl
Spencerport, NY USA
Post Number: 210
Here's the specs for that amp.
http://www.sonicelectronix.com/item_2076.html
