Anonymous | I HAVE 2 GRAND AND LIKE TO GET A SYSTEM FOR HOME THEATER USE MAINLY. WANT THE FEEL OF A TRUE HT EXPERIENCE. GIVE ME THE BEST RECCOMENDATION. THANKYOU |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7641 Registered: May-04 | Go out and listen. That's the best advice. |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1458 Registered: Dec-04 | and stop yelling. |
Anonymous | sorry about that, id like to check things out but if you guys could narrow it down for me that will be great, HT mainly. thankyou |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1461 Registered: Dec-04 | If you are talking 2k with connects, out the door, bb and cc have ok stuff. HT is pretty easy, really. An athena setup is pretty good, but you might have to barter for a good receiver. |
Anonymous | even 3k is possible |
Gold Member Username: NuckParkhill, Ontario Canada Post Number: 1471 Registered: Dec-04 | Do you have stereo stores near you Anon? |
Anonymous | I'm anonymous because I am just here to waste your time and input. |
Gold Member Username: Project6Post Number: 6382 Registered: Dec-03 | This is why you really should not post as anonymous if you want some help. Maybe you are just wasting time? |
Anonymous | if u guys dont want to give advise just say so. it should not be about posting as anonymous or not. thankyou. |
New member Username: IcmenuJackson, Tn USA Post Number: 8 Registered: Feb-06 | If I were to look at a HT system for the budget you are on I would check out some of the following. Receivers: Onkyo, Denon, Yamaha, Harmon/Kardon. Speakers: Polk Audio, Infinity, BIC, Bose?? Also, use nothing smaller than a 16 guage speaker wire to set up speakers. Just a few suggestions. (always spend more money on your speakers) |
Bronze Member Username: StevizardIndianapolis, Indiana USA Post Number: 27 Registered: Aug-05 | Anonymous, In the audio world, a $2000.00 budget is small but in the Home Theater world it is VERY small. However, you can make a few smart moves to maximize the buying power of your budget. SUGGESTION #1 - Buy small speakers with GREAT drivers. Speakers contain 3 main components: 1) Drivers, 2) Electronics, and 3) Cabinets. Nearly a full one-half of the cost of making a speaker goes to the cabinet, the rest goes to the drivers and electronics. Small speakers with excellent drivers & electronics will out-perform most large speakers at the same price point. SUGGESTION #2 - Spend more on speakers than on the A/V Receiver. As has been said many times on this forum, the speakers make the system. NOTHING will improve a sound system more than good speakers. SUGGESTION #3 - Find an AVR with the power and features that are important to you. There are many great AVRs out there that don't have THX, THX Select, or THX Ultra 2 certification. Manufacturers must pay fees to license these certifications, which drives up the price of their AVRs. Some manufacturers refuse to play the THX game, and instead allow their AVRs to stand on their own merits (the specs). There are many audiophile quality pre/pro/tuners on the market that do not have THX certifications. RBH Sound makes some of the best drivers on the planet. Check out the three speaker systems below. http://www.rbhsound.com/hometheater0798.shtml http://www.avrev.com/equip/rbhmcseries/ http://www.hometheatersound.com/equipment/rbh_ac_series.htm ![]() ![]() Sherwood Newcastle produces great AVRs at really good price points. http:\www.sherwoodusa.com |
