Subs That Are 3ohm and 1.5ohms
Kyle D
how would you wire these kind of subs? im confused....I've only heard of 2ohm and 4ohm subs....thanks for your help
Username: Redliner
Wilmington, Ma
Post Number: 107
what kind of subs are they
Kyle D
13W7--dual 1.5 ohms
Username: James1115
Wilton, Ct
Post Number: 4334
wire them with a jl 1000/1 to 3ohms. JL did that so that you kind of a forced to use their amps with their subs.
Kyle D
so that means I wont be able to use my mb quart raa1000
Username: Tjmutlow
Post Number: 390
at 3ohms and then not enough power.
Kyle D
ok so, forget about the 13W7-3.......would two 13w6v2 have spl and sq comparable to the 13W7
Username: Tjmutlow
Post Number: 397
probably better they are dual 4, but remember that amp is rated at 14.4 volts, but it should be ok.
Username: Robert_d
MIA, FL USA
Post Number: 440
how are the xenon amps ... they got a 1200 rms @ 1-4 ohms
Username: James1115
Wilton, Ct
Post Number: 4341
it all depends on the box really! I am not a big fan of the w6v2 in a sealed enclosure but in a nice ported enclosure tuned low look out it really packs a punch. 2-13w6v2's in a vented enclosure tuned to 27-30 would sound much better then a 13w7 IMO. The xenon amps are decent for the money. They are not up to par with phoenix gold ten years ago but they are decent.
