Playing SACD on a computer?
Hello, I wonder if it's possible to play a SACD using my computer-DVD player? (so I don't have to buy a SACD player) (I want the surround sound)
Username: Sem
New York USA
Post Number: 551
You'll need the SACD player to decode the Hi-Rez SACD layer. Your PC cd or dvd drive will be able to play the redbook cd layer of the disc, as long as one exists.
milpai
Sony is coming out with a new desktop that can burn/play SACDs. You may need to find out more info. on that. read it at audioasylum.com
