Brad from PA Unregistered guest | Ok i am geting 2kicker solo L7's and a hifonics brutis amp 1200 watts at 1 ohm x 1 ...i was wondering if i hooked my speakers in parallel if the wattage per speaker would be 600 rms b/c thats what the speakers are rated for and they are to expensive to blow out lol. |
Silver Member Username: RovinTrinidad & T... Post Number: 771 Registered: Jul-05 | If u haven't heard by now - Hifonics amps are overated . They put out according to a few tests done - about 70% actual rms . Its a brand for ppl who don't have much $ . So u do the math & pick a model that @ 70% of advertised power will give u the power u need ......... |
Silver Member Username: JaackdethUnited States Post Number: 648 Registered: Sep-04 | Brad, I had a similiar set-up way back, and save your $ and try and get something other then the Hifonics~ |
Brad from PA Unregistered guest | well what if i got a ma audio hk-1998 1200 watts at 1 ohm ? |
Brad from PA Unregistered guest | and will that give me 600 watts to each speaker if i hooked it up liek i said parallel? |
Silver Member Username: RovinTrinidad & T... Post Number: 799 Registered: Jul-05 | well this link has been posted like a million times now but i guess i have to post it again for your benefit http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic |
brad from PA Unregistered guest | sorry im not hardcore like you are Rovin...we can't all be as car audio masters like you |
Silver Member Username: RovinTrinidad & T... Post Number: 822 Registered: Jul-05 | I never meant to come off sounding offensive dude but a few times i posted that link a few ppl said they were tired of seeing it . I am trying to help u could cause if someone else told u thats not a good brand then u'd be asking about another . Never said i'm hardcore or master @ anything - just trying to help from whatever little i do know ... ![]() |
Brad from PA Unregistered guest | aight well i guess it just came off wrong lol sorry about the mix up |
