New Subwoofer Plans
Username: Soberskull
San Lorenzo, California United States
Post Number: 14
Alright. I am doing 2 setup's now. 2 10" and 2 12". possibly 2 15" too. Basicly for the 10", i'm looking at more good sound quality then being loudness, and I was looking into the JL subs for that. Is there anything else I should to look into / listen to. Also, the 12" and 15", I am mostly looking for SPL. SQ doesn't really matter that much, but would be recommended with the SPL. I was looking into the RE XXX but for being that hard to get, i'm just going to skip out of those. I was thinking of going with some Rockford Fosgate's. Again, would anyone else recommend anything else? Thanks again!
Username: Mikechec9
Chicago/atlanta
Post Number: 356
Adire is said to begin distribution at the end of july (then again they said the same about June).
Adire Brahmas
http://adireaudio.com/
ID Max http://www.imagedynamicsusa.com/pro...=idmax&type=sub
Digital Designs
http://www.ddaudio.com/dd/default.asp
Sound Splinter
http://www.soundsplinter.com/
Ascendant Audio
http://www.ascendantaudio.com/
Elemental Designs
http://www.edesignaudio.com/us.php
Treo
http://www.treoonline.com/index.html
Crystal Comps
http://www.lightav.com/car/crystal/crystal.html
Diamond Audio D9
http://www.diamondaudio.com/product...&type=28&line=1
Eclipse Ti
http://www.eclipse-web.com/
my personal top 10. jmo
Username: Hdubb
Farmington, Nm Usa
Post Number: 1960
id have to say dd on this one, go with the 3500 series.
Post Number: 16
I'll check them out. Specially DD. I had a few people point them out. Thanks :-)
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 177
for the SPL, Kicker Solo X all the way, no SQ but it will get loud
