What sub do i need?
tommymagal
hi, recently bought a 5 channel amp for my car with the sub output at 300wRMS, what is the minimum power handling capability i should look for when i buy a sub so that it does not get damaged?
Username: Taylor17
Kopperl, Texas
Post Number: 2290
You should be able to find a sub for that amp, no problem. Just look for a sub that is 200/400 rms, and you should be fine.
tommymagal
thanks for advice
